- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
For some reason my gcode post for a simple 2d contour opperation to machine a step in my part 0.5 mm deep is creating a two pass operation, in the first pass the mill is commanded to machine air at the surface of the part Z relative to the setpoint of model top being 0. The second pass it plunges to 0.5 mm depth and completes the part. i can see if this was two steps (say -0.25 mm the first pass and 0.5 mm the second) but not what is happening. My mill is a Sherline 5400 so 0.25 mm depths of cut would be reasonable. What might I check in my setup to correct this issue?
