- Mark as New
 - Bookmark
 - Subscribe
 - Mute
 - Subscribe to RSS Feed
 - Permalink
 - Report
A few weeks ago I programmed a 1/8-27 NPS threadmilling operation. The selected face was the hole diameter modeled as the drill size, so I input a number into the Pitch Diameter Offset (PDO) field under Passes. I few test cuts later, tweaking the number, I achieved the fit I was looking for.
Fine.
Today, using the same strategy, I programmed a M14x1.5 threadmilling op. and have found if I enter the PDO, the tool goes way beyond the desired nominal thread major diameter (in this case 14mm).  The selected hole is again, modeled at the drill size, so the PDO should be about 0.059".
In the screencast below I begin with the 1/8-27 op from a few weeks ago when I ran these parts - I highlight the 0.049" PDO entry before Simulating to demonstrate the tool cuts almost to the outer circle (representing the 1/8-27 major diameter of 0.398").
Then, I flip over to a quick model demonstrating the difficulty with the M14 operation -
The first thing I show is a 0 in the PDO field. This SHOULD walk the tool around the inside of the inner circle since it is modeled to the minor diameter for M14x1.5 (0.492"). Instead, it cuts beyond the major diameter (outer circle modeled at 0.551").
I then enter the delta in the PDO field (0.059") which should put the tool at the inside of the outer circle - It's way beyond that.
Lastly, I change the PDO back to 0" and enter 0.011" in Stock To Leave, which represents the fit I'm looking for based on some hours of _____ around with this.
All simulations are run with the FLUTE selected to display, so it's not the shank I'm seeing beyond the major diameter.
What could be going on with the PDO behavior in the M14 op? All the tool parameters are entered correctly, including the diameter of the threadmill cutting area, which is on my tool is clearly labeled 0.360".
Before posting, trying to figure out if the problem is me, I have subsequently modeled up a quick representation of the 1/8-27 op just to prove to myself that I'm not crazy - it works as expected. I then modeled up an M6x1.0 threadmill op and it does the same as the M14 going way out of bounds...so thinking it's somehow a "metric thing" I then try out a 1/4-20 and it does the same as the metric threadmills. Seems that new threadmills I've entered in the tool library exhibit this behavior. The 1/8-27 has been in my library since ~October 2017, I believe. All others are new additions.
