Haas ST35Y Post issues
CNCMachineShop
CNCMachineShop
Does anyone have the problem with the HAAS ST35Y lathe post processor? after I upgrade to the version 44114 then the "Use sequence numbers only on tool change" does not work anymore. Does anyone know how to fix the issues, this feature is really good and handy.
Thanks for any help.
AchimN
Hi @CNCMachineShop ,
thanks for your feedback.
You are correct, this feature no longer works with the latest post update, sorry for the inconvenience.
To get it fixed, please copy the code line below into the beginning of the onOpen function as shown in the screenshot. I´ll make a ticket for it so that we can get it fixed in the library posts as well.
showSequenceNumbers = getProperty("showSequenceNumbers");
Achim.N
Principal Technology Consultant
CNCMachineShop
Perfect
tgford58
@CNCMachineShop
I've made that change but it has not altered the output.  I have Yes selected in Formats/use sequence numbers.
AchimN
I´ve just tested here, works as expected when the missing line gets added to the post. Can you share your post? Then i´ll take a look
Achim.N
AchimN
FYI, the issue has been fixed in all HAAS posts now, the updates will show up next Monday on the post library.
Thanks again for your feedback!
Achim.N
CNCMachineShop
I GOT IT !!!!!
