Haas NGC Post G95
Haas NGC Post G95
moore.michaelw
Message 1 of 13
Haas NGC Post G95
moore.michaelw
I recently got a new to me Haas VF2 with NGC, for years I have been using Fadal mills with both Fadal and Fanuc controls, and the posts have always had a radio button to click to enable G95 (IPR) feedrates. The NGC post does not have this. Can someone modify the post, or explain to me the steps needed to take, to add G95 as an option not just for tapping but for everything.
Thanks in advance for any help.
Replies (12)
Message 2 of 13
Don.Cyr
You have to look in the post properties under preferences and check the box.
Please click "Accept Solution" if I helped with your question or issue.
Message 3 of 13
moore.michaelw
That's for tapping only. I want G95 for everything.
Message 4 of 13
programming2C78B
then you are looking for G99 to set your feedrate.
Please click "Accept Solution" if what I wrote solved your issue!
Message 5 of 13
moore.michaelw
G99 is for returning to R plane in a canned cycle.
G94 is IPM
G95 is IPR
I just want to know how to get a check box to turn on IPR for all tools,
not just tapping.
Message 6 of 13
programming2C78B
You need to be more precise then with "everything". You mean all canned cycles. FYI you can still program as IPR inside fusion and allow it to post out in IPM.
https://www.haascnc.com/service/codes-settings.type=gcode.machine=lathe.value=G99.html
Message 7 of 13
moore.michaelw
I do not want any federate, anywhere in my program to post as IPM.
Message 8 of 13
moore.michaelw
For example, if you look at the Fanuc post, you will see in the preferences tab the seventh option down is simply titled "Use G95"
Can this please be added to the NGC post?
Message 9 of 13
Don.Cyr
Check the box on the tool tab. If you have the latest NGC post it will output the correct code.
Message 10 of 13
Don.Cyr
Look for this section in the post, if your not using the latest or you have a modified post.
Message 11 of 13
moore.michaelw
There is only one issue with this and that is that this option is available in drilling but not in milling.
I want to be able to post my entire program in IPR.
Message 12 of 13
programming2C78B
As I said before
"then you are looking for G99 to set your feedrate."
Message 13 of 13
moore.michaelw
G99 for feedrate is for lathes.
This is a mill.
