groove on face using 5th rotation axis.
trains420
Message 1 of 11
trains420
Hello, I need to create a groove on the front of the rotating part. For the best possible geometry, I would need to use a rotary axis, but I don't know how to do it. I tried to use the Wrap toolpath and rotary functions, but these only work perpedicular to the axis of rotation. I need to mill in the axis of rotation.
Replies (10)
Message 2 of 11
mathew.hutton
Hi @trains420
Can you attach your project?
Mat
Mathew Hutton
Manufacturing Specialist
Message 3 of 11
trains420
here it is
Message 4 of 11
mathew.hutton
Hi @trains420
Thanks for attaching your file. Can you show me a screenshot selecting the geometry that you want to try to machine as i'm unsure what you're referring to here
Mat
Mathew Hutton
Message 5 of 11
trains420
I want to mill this groove with a 1mm cutter using a rotary axis.
X, Y are positioned. Only the B and Z axes move (0.05mm per revolution of the B axis).Bez názvu.png
Message 6 of 11
mathew.hutton
Hi @trains420
Is there any reason in particular that you want to use a rotary or 5 axis toolpath on this though, the geometry is flat with perpendicular walls so i don't see why you'd need a multi-axis toolpath strategy for this? I have had a mess around and i think because you have your machine selected in your setup, you can't access some of the multi-axis toolpath options. If you deselect your machine from your setup it gives you access to these options then.
Mat
Mathew Hutton
Message 7 of 11
trains420
The reason is that when using a rotary axis, I achieve greater geometric accuracy. If I do this with linear X, Y axes, I will have a geometric inaccuracy around 0.05mm. Unfortunately, I will not achieve a better result on this machine at the moment.
a simple example
G00 X3 Y0
G00 Z2
G01 B360 Z-0.1
G01 B360 Z-0.2
Is it possible to program it like this in Fusion?
Message 8 of 11
mathew.hutton
Hi @trains420
It sounds like you are describing you want to use polar milling essentially. But this involves revolving around a C axis, not a B axis. The B axis revolves around the Y axis. To machine that slot in the orientation you have your setup in, it would need to rotate the C axis? I'm pretty sure you can activate this in your post by enabling polar mode if you have it set up?
Mat
Mathew Hutton
Message 9 of 11
trains420
Autodesk representation in the Czech Republic produces a five-axis postprocessor for me. I bought the 4th and 5th axes recently, and now I'm dealing with everything else. So I'll be able to test this when they deliver it to me.
So if I want to mill this way, it doesn't matter what strategy I use? Could I use 2D contour for this, and then activate polar milling in the postprocessor, and nothing more?
Message 10 of 11
mathew.hutton
Hi @trains420
Yes i think in your case you would program this normally and then when you post the program, you should have the option to force polar mode instead of XY mode. The post should then produce the code for you. I normally don't use polar mode unless the part i am machining exceeds my Y axis range, so then if that is the case, the post automatically forces polar mode. See this thread as reference: https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Mat
Mathew Hutton
Message 11 of 11
trains420
Thank you for the explanation. When I have the postprocessor available, I'll try it. Thank you for now.
