I have been using Fusion360 for 3 years, originally on a start up licence and now as personal. Using to generate g-code/models for CNC Router and 3D printer
I have a really simple job equivalent to a piece of 4x2 (90x45mm) that I want to trim to a curved profile. I have created many similar jobs in the past so I know the workflow - or I knew the old workflow.
I can create a design, switch to manufacture, create a setup and then a 2d profile. Simulation works fine but when I try to create a GRBL post process file I get the following. I have searched for a solution but have uncovered nothing to date. I also tried a complete reinstall but the problem persists.
Can anyone point to a. solution?
Maurice
Here's the log output.
Information: Configuration: Grbl
Information: Vendor: grbl
Information: Posting intermediate data to '/Users/maurice/CNC-Laser-3D files/_Design and Manufacture files/CNC files/press-side-ends.nc'
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Start time: Sat Dec 12 23:39:44 2020
Loading locale from '/Users/maurice/Library/Application Support/Autodesk/webdeploy/production/5279b777792e8250576af6da9784c53f10a39cdc/Autodesk Fusion 360.app/Contents/Libraries/Applications/CAM360/Data/Posts/common.en.lang'
Post processor engine: 4.5729.0
Configuration path: /Users/maurice/Library/Application Support/Autodesk/webdeploy/production/5279b777792e8250576af6da9784c53f10a39cdc/Autodesk Fusion 360.app/Contents/Libraries/Applications/CAM360/Data/Posts/grbl.cps
Include paths: /Users/maurice/Library/Application Support/Autodesk/webdeploy/production/5279b777792e8250576af6da9784c53f10a39cdc/Autodesk Fusion 360.app/Contents/Libraries/Applications/CAM360/Data/Posts
Configuration modification date: Fri Dec 11 08:47:28 2020
Output path: /Users/maurice/CNC-Laser-3D files/_Design and Manufacture files/CNC files/press-side-ends.nc
Checksum of intermediate NC data: 0091e4efc725c258188b33fc57f67553
Checksum of configuration: 9e433db1a372e6cad74733334138e949
Vendor url: https://github.com/gnea/grbl/wiki
Legal: Copyright (C) 2012-2020 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.9442
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Unsupported 'suction' coolant.
Error in operation: '2D Contour1'
Failed while processing onSection() for record 478.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Sat Dec 12 23:39:44 2020
Post processing failed.
