Hello all, I have a rookie question about my speeds/feeds calculator, Please keep in mind I have only had my CNC machine for about 13 months and been making chips for roughly 10 months. I have been running a lot of my parts at low rpm with low feed rates with great results however I want to learn how to speed things up as I have a job coming up where time is a factor. I am using a speed and feed calculator that is giving me a feed rate of 48 in/per at aprox. 8k spindle speed on a .250 3 flute with a 'radial' of .013 at full depth/axial of .350
Here is the confusing part for me, Fusion defaults to .1 radial under optimal load however if I input .013 as the speed and feed calculator recommends I obviously get and insanely long tool path due to the small step over. Now as fusion describes, Adaptive HSM varies so that the tool does not over load. Do I leave the default Fusion gives me based on the tool diameter or?
I have had success using the calculator with micro "2 flute" tooling however with the larger tooling the stepover/radial from my calculator vs optimal load in fusion on 3-5 flute end mills are just not jiving due to my inexperience.
Thank you so much in advance for any help possible in explaining/clarifying things for me 🙂
