Graphic bug in Manufacturing/Simulation, Tool is following cursor all the time.
RaftechEng
RaftechEng
Since last update I got a distracting bug that also makes the program lag a bit.  In manufacturing environment if a toolpath/ operation is selected the tool follows the cursor. This is happening outside the simulation environment.
I've done multiple clean installs, Originally did a reinstall because I wasn't able to see my tools at all (in simulation).
I tried toggling preview feature ' in process stock", no change.
I haven't been able to find any related topics on the forum.
please help!
-Raf
screencast attached
<iframe width="640" height="620" src="https://screencast.autodesk.com/Embed/Timeline/88d00635-8c12-4af5-a9c9-ac82001f21b0" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
RaftechEng
Sorry haven't been able to attach the proper screen cap.
Edit- looks like the link up top works
seth.madore
CTRL (or Command) + T will turn that off. It's off by default, so it's possible you accidentally activated it 🙂
Seth Madore
RaftechEng
Thanks Seth! That was easy:)
scottnewman
Seth,
On 3-20-2023 mine started making the tool follow the curser around in Manufacturing mode when editing tool paths.
Control "T" does not turn it off
I have Windows 10 ver 22H2
Thanks, Scott
seth.madore
If CTRL+T doesn't turn it off (which it should), you can also click down here:
Seth Madore
scottnewman
I tried CNTL +T many times to get the tool from following the cursor in Fusion manufacturing while editing a tool path, but I could not get rid of the tool. I finally removed it by Right-Clicking on the image of the tool and selecting OK. The tool disappeared and CNTL+T works to toggle it on and off.
[cid:[email protected]]
