Geodesic: Significantly different stepover distances when switching the type from "Blend" to "Scallop"
eerier_bleach0f
eerier_bleach0f
Same exact settings. Literally copy/pasted the toolpath but changed the type from blend to scallop. Same max stepover values of .04". But here's what the toolpath looks like when it's set to blend:
And what it looks like when setting the type to scallop:
Autodesk's most dedicated bug reporter: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/15188348
a.laasW8M6T
That's expected behavior especially for surface selections like that.
Blend will not exceed the max stepover while staying between the Guide curves, which means it has to make very small stepovers in some areas, that is a particularly extreme example because choosing blend isn't the best for that type of geometry.
Andrew Laas
Senior Machinist, Scott Automation
