G49 before G69 Fanuc G68.2/G69
mario.kaiserXZ5XS
Message 1 of 9
mario.kaiserXZ5XS
Hello together,
we are having a 5-axis simultan machine and a Fanuc 30is control. Also we are using the G68.2 code for 5-axis machining.
The problem here is the output from the standard fanuc post. See here my example:
In row N150 there is coming G69, the fanuc control wnats to have before this a G49. So how can i manipulate here the post to do this. THanks for your help!
N50 G68.2 X0. Y0. Z0. I90. J90. K180.
N55 G53.1
N60 M08
N65 G00 X-38.216 Y2.907
N70 G43 Z100. H45
N75 G00 Z87.85
N80 G01 Z75.552 F28.
N85 X-36.276 Y7.515 F84.
N90 X-34.777 Y11.074 Z75.537
N95 X-33.279 Y14.633 Z75.492
N100 X-31.782 Y18.191 Z75.418
N105 X-30.287 Y21.75 Z75.313
N110 X-28.794 Y25.309 Z75.18
N115 X-27.305 Y28.867 Z75.016
N120 X-25.818 Y32.426 Z74.823
N125 X-24.336 Y35.985 Z74.601
N130 X-22.42 Y40.593 Z74.293
N135 Z87.85
N140 G00 Z100.
N145 G53 G00 Z0.
(TRACE1 2)
N150 G69
N155 G68.2 X0. Y0. Z0. I96.207 J90. K180.
N160 G53.1
N165 G49
Replies (8)
Message 2 of 9
AdamKunzo
Try this post.
Message 3 of 9
mario.kaiserXZ5XS
Hello Adam,
i have tried this but then the Workplane compensation G68.2/G69 is gone
Message 4 of 9
AdamKunzo
Thats wierd. This is output I am getting:
(2D-FACE2)
N115 G49
N120 G69
N125 G68.2 X0. Y0. Z0. I-90. J30. K90.
N130 G53.1
N135 G00 X-40.203 Y-31.135
N140 G43 Z40. H02
Message 5 of 9
mario.kaiserXZ5XS
No, this is what i am getting out from your processor. I have a machine also which i am using, could be this the problem?
N30 T71 M06
N35 S9549 M03
N40 G54
N45 G92 C360.
N50 G00 A-90. C270.682
N55 M08
N60 G00 X99.993 Y1.19
N65 G43.4 Z-5.675 H71
N70 G00 X89.994 Y1.071
N75 G01 X85.794 Y1.021 F255.
N80 X78.896 Y0.939
N85 X78.902 Y0.128 Z-7.519 C270.093 F764.
N90 X78.899 Y-0.654 Z-9.298 C269.525
N95 X78.889 Y-1.436 Z-11.078 C268.957
N100 X78.871 Y-2.219 Z-12.857 C268.388
N105 X78.845 Y-3.003 Z-14.636 C267.819
N110 X78.811 Y-3.787 Z-16.416 C267.249
N115 X78.769 Y-4.571 Z-18.195 C266.679
N120 X78.72 Y-5.355 Z-19.975 C266.108
N125 X78.663 Y-6.139 Z-21.754 C265.538
N130 X78.598 Y-6.922 Z-23.533 C264.967
N135 X78.525 Y-7.704 Z-25.313 C264.397
N140 X78.444 Y-8.485 Z-27.092 C263.826
N145 X78.356 Y-9.265 Z-28.871 C263.256
N150 X78.26 Y-10.043 Z-30.651 C262.687
N155 X78.157 Y-10.82 Z-32.43 C262.118
N160 X78.045 Y-11.594 Z-34.209 C261.55
N165 X77.927 Y-12.367 Z-35.989 C260.982
N170 X77.796 Y-13.167 Z-37.833 C260.394
N175 G00 X98.598 Y-16.688
N180 G53 G00 Z0.
And this is from my postprocessor which i am using now
(2D-KONTUR8)
N30 T71 M106
N35 S9549 M03
N40 G17 G90 G94
N45 G54
N50 G92 C360.
N55 G00 A-90. C270.682
N60 M08
N65 G68.2 X0. Y0. Z0. I90.682 J90. K180.
N70 G53.1
N75 G00 X0. Y5.675
N80 G69
N85 G43.4 H71
N90 G00 X99.993 Y1.19 Z-5.675 A-90. C270.682
N95 X89.994 Y1.071
N100 G01 X85.794 Y1.021 F255.
N105 X78.896 Y0.939
N110 X78.902 Y0.128 Z-7.519 C270.093 F764.
N115 X78.899 Y-0.654 Z-9.298 C269.525
N120 X78.889 Y-1.436 Z-11.078 C268.957
N125 X78.871 Y-2.219 Z-12.857 C268.388
N130 X78.845 Y-3.003 Z-14.636 C267.819
N135 X78.811 Y-3.787 Z-16.416 C267.249
N140 X78.769 Y-4.571 Z-18.195 C266.679
N145 X78.72 Y-5.355 Z-19.975 C266.108
N150 X78.663 Y-6.139 Z-21.754 C265.538
N155 X78.598 Y-6.922 Z-23.533 C264.967
N160 X78.525 Y-7.704 Z-25.313 C264.397
N165 X78.444 Y-8.485 Z-27.092 C263.826
N170 X78.356 Y-9.265 Z-28.871 C263.256
N175 X78.26 Y-10.043 Z-30.651 C262.687
N180 X78.157 Y-10.82 Z-32.43 C262.118
N185 X78.045 Y-11.594 Z-34.209 C261.55
N190 X77.927 Y-12.367 Z-35.989 C260.982
N195 X77.796 Y-13.167 Z-37.833 C260.394
N200 G00 X98.598 Y-16.688
N205 G53 G00 Z0.
Message 6 of 9
AdamKunzo
There are properties that can be set up differently on your side and using machine definition also affects the output.
Open your .cps file, seach for "68.2" and add "disableLengthCompensation();"
if (abc.isNonZero()) {
        gRotationModal.reset();
        writeBlock(gRotationModal.format(68.2), "X" + xyzFormat.format(0), "Y" + xyzFormat.format(0), "Z" + xyzFormat.format(0), "I" + abcFormat.format(abc.x), "J" + abcFormat.format(abc.y), "K" + abcFormat.format(abc.z)); // set frame
        writeBlock(gFormat.format(53.1)); // turn machine
Message 7 of 9
mario.kaiserXZ5XS
Better but not at the goal, now G49 is standing after G69, i need it before....
N865 G00 Z119.
N870 G53 G00 Z0.
(2D-TASCHE2 5)
N875 G69
N880 G49
N885 G68.2 X0. Y0. Z0. I-90. J90. K180.
N890 G53.1
Message 8 of 9
boopathi.sivakumar
Hi @mario.kaiserXZ5XS
Open the library fanuc post find for the following code in the onSection top
    if ((insertToolCall && !isFirstSection()) || smoothing.cancel) {
      setSmoothing(false);
 And change it to
    if (((insertToolCall || newWorkPlane) && !isFirstSection()) || smoothing.cancel) {
save the post and test it
Boopathi Sivakumar
Principal Technology Consultant
Message 9 of 9
mario.kaiserXZ5XS
Hello Adam,
can you check this model and the machine with your post if you are getting a G68.2 out or not. Or is this not needed here
The machining what i am talking is "Muster7" with "2D-Kontur8"
And the question, is the output from the PP OK for this machining?
And does this have any influence how i position the part in fusion with the machine for the post?
Mario
