G code error Radius to end of arc differs from radius to start
IanRobertson
Message 1 of 10
IanRobertson
Anybody know how to solve this? I posted about it earlier and thought it was solved, not by a long shot, comes up whn I try to run most paths and therefore they will not run.
Replies (9)
Message 2 of 10
Steinwerks
Can you share your part and post processor here?
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 3 of 10
IanRobertson
The Post Processor is emc.cps. I will have to clean up some of the cryptic names before I post the file, if I can figure out how!
Message 4 of 10
Steinwerks
File -> Export and select .F3D
Neal Stein
Find me on:
Message 5 of 10
IanRobertson
I guess I don't understand.
To export as f3d I have to go to another program A360 but it does not list f3d but something else. I export it and I get an email with link to download it. I download it and it is a f3d file after all. I try to open it but it says no. I change to work offline but I still can't open it.
Wow! What ever happened to "export"?
How do I open this file? Do I have to upload it again? What is the point of "work offline" if you can't?
Like I said I guess I don't understand?
I have attached the file and I hope there are no foul names/ langauge enclosed in the file. I must stop doing that, sorry in advance.
Ian
Message 6 of 10
HughesTooling
On the file menu there's an option Export, to import the file use New Design From File.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 7 of 10
HughesTooling
The file you attached isn't going to be any help as there are no operations setup in the CAM workspace.
Mark
Mark Hughes
Message 8 of 10
IanRobertson
When I try to export I get as per the screen shot hence my going to A360 as per the help files.
Message 9 of 10
IanRobertson
Cbviously the screen shot did not work, try again.
Message 10 of 10
jeff.walters
This is most likely because you have external references in you file (linked part?). You will need to save it out as an f3z file. The link below should help with that. It will be the second part “From the Autodesk 360 Dashboard:”
http://fusion360.autodesk.com/learning/learning.html?guid=kA230000000eDVZ
Jeff Walters
Senior Support Engineer, CAM
