Fusion post process error
calironfabco
Observer Observer
calironfabco
Observer
Observer
Expressing frustration over an error when posting out partial sections on a setup. I only wanted to post the four adaptive passes for my high feed mill out of an eleven toolpaths in the setup. While running the feed mill was in the middle of the 2nd pass cutting it traveled down and out to the t6 contour pass causing a crash and its probably going to scrap this 3ft chunk of p20 tool steel.
mazak post ver. 44214
programming2C78B
we will need to see a code or file for this one....We have no idea what's wrong or what things were meant to look like!
Please click "Accept Solution" if what I wrote solved your issue!
calironfabco
Observer
Observer
 i forgot to add this one to the original post, this is the desired posted pass and the code that ran. I also attached the ncviewer display in the original post showing that it cut off on the 2nd pocket. In the code it just took a xyzjk move through the block into T6's contour pass. I also exported the post used
