Fusion generating jagged finishing toolpaths
clf77
Message 1 of 8
clf77
 Why does fusion generate the steep and shallow toolpath jagged? There is no way this is the optimal toolpath.
Replies (7)
Message 2 of 8
Unixprocessing
파일을 올려주세요
Message 3 of 8
a.laasW8M6T
No that doesn't look good at all.
Can you share the problem file here? There may be some setting that are causing the issue.
Goto File>Export>Save as .f3d/.f3z
Andrew Laas
Senior Machinist, Scott Automation
Message 4 of 8
clf77
Here is the file. Sorry for the delay in uploading originally.
Message 5 of 8
a.laasW8M6T
Hi
I believe this is a Bug
https://forums.autodesk.com/t5/fusion-manufacture/steep-and-shallow/m-p/12511120
Geodesic May be a good option here until it is fixed
see attached
Andrew Laas
Message 6 of 8
clf77
Got it thank you.
Also, my adaptive (same file) does these small passes where the path really should be continuous. Any idea what is causing this?
Message 7 of 8
a.laasW8M6T
Its something called whisper cuts, The developers are actively working on reducing these.
There are some improvements that may come out in the next release.
Andrew Laas
Message 8 of 8
seth.madore
Thanks for the file, I've added your sample to CAM-51015 for our investigation and testing.
Seth Madore
