Fusion does not save operation parameters as default
KRoser_12
Message 1 of 9
KRoser_12
Hello.
After lates update fusion stoped saving operation parameters as default.
When i right click on operation "save parameters as default" seted parameter works until i shut down fusion.
After reboot operation parameters are all set to fusion default.
Is this a bug or iam doing something wrong?
Replies (8)
Message 2 of 9
KRoser_12
No info about this? Only i have this problem? I canot figure out reason why and it is extremely anoying.
Thanks for reply.
Message 3 of 9
seth.madore
I don't think I've heard any other reports of this. When was the last time you did a full uninstall and reinstall of Fusion?
Seth Madore
Message 4 of 9
KRoser_12
Thank you so much for reply apretiate it.
I tried Fusion 360 Cleaner app just a few days ago did not help.
I have been using Fusion for years and never have this problem.
Iam using Fusion on 2 pcs and this fusion act this way on both of them.
Message 5 of 9
KRoser_12
OK i tried full reinstall of fusion and no changes.
I tried reset fusion preferences to default and i think fusion does not save any settings (in preference tabs they are saved) but after preference reset i cant get rid of grid visual setting when i turn it off in fusion it is gone but after fusion restart it is back as i was same with CAM operation default.
Fusion is nearly imposible to use with this issue.
I have no idea what is it causing.
Message 6 of 9
KRoser_12
I cant step over my issue with fusion anymore. My company relly on fusion and i use fusion every day.
I have no idea what to do next.
So please Iam begging someone for help with this.
I recorded a little exampe. It is completely new and clean install of windows 11 on VM and clean instal of fusion just sign on to my account. Fusion just does not save and remember any setting that i change in fusion and after fusion restart everything i back to default.
I even tried full OS clean reinstal on my personal computer and i have same issue.
https://drive.google.com/file/d/1zC78bXupTFnFgjdCvnM2k6LIeVpRkJbf/view?usp=sharing
So please if anyone has any suggestions.
Thanks for help.
Message 7 of 9
jswickJ9PWC
I am having the same issues. It's been happening for a few weeks and I've just put up with it because I have bigger issues to focus on.
Version:
2.0.12888
Active Plan: Fusion 360, Subscription
Windows 10 Pro 21H2 x86_64 (19044.1706)
Message 8 of 9
maxSE6ML
Im am having the same issue also. Its so anoying when using fusion CAM every single day. THIS NEED TO BE FIXED!
It only seems to happen with some settings.
e.g.
Setup settings seems to be saved correctly.
But heights when drilling doesn't save.
Message 9 of 9
ltomuta
I have just saved new defaults for the drilling operation (expressions linking parameters in the heights tab with hole's selection mode) and the new defauls were saved correctly and still available after restart.
Defaults exported before the test and after restaring show the changes as still present:
Tested with the latest build, on Windows 11.
If you are still seeing this issue you should provide more detail. Like which exact parameter you have saved a new default for and what that default value/expression was.
Defaults exported before/after restarting the app would also help.
