- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've noticed this on a few different toolpaths, but this is the worst offender yet and prompted my investigation.
Why do toolpaths finish a cut and then return to the center before leading out, instead of leading out from the last cut?
It wastes time, and with G96 on it ramps the spindle up unnecessarily.
It also might be causing the warning about crossing the centerline, not sure about that though...
Is there a way to control what point the retract moves are started from?
This path starts cutting from a hole drilled in the center, plunging axially and stepping out radially. When it gets to the outside edge of the part it moves back to center (bold yellow line) before retracting to the safe Z. Is there a way to retract to the safe Z from the outside edge of the part?
