Fusion 360 Manufacture gouge check
dkakuma
dkakuma
I want to know if there is a way to check a toolpath for gouges into my part. In powermill there is collision and gouge check tab and when the toolpath cuts into the part the toolpath becomes red so you can see it has a problem.
Is any way to do that in  Fusion 360??
jameshorne0503
The tool and holder will flash red on a collision. If you want to find collisions without just playing and watching, in the second tab of the simulate menu (info) there is an option called verification. Running this will find any collisions and calculate the amount of stock removed. The bar at the bottom of the screen where you can scrub through the simulation will now have red sections anywhere there is a collision and hovering over them will tell you what those collisions are.
Hope this helps!
