Fusion 360 machine library missing
wpillinger
Message 1 of 20
wpillinger
I've just started using the Manufacture module, focusing on AM.
However, when I open the Machine Library, it is empty, particularly the Fusion 360 library is not showing (see attached screenshot). Same on two PC installations.
Couldn't find any guidance to fix this.
Thanks for support, regards
Willy
Replies (19)
Message 2 of 20
I'm also having the same issue after redownloading/installing fusion 360. I'm using an educational license, but i don't think that is the primary issue.
Message 3 of 20
rfassberg
Same issue here.  Is something broken in latest update??
Message 4 of 20
FrodoLoggins
Something's broken in every release lol
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Message 5 of 20
I rebooted my fusion 360 and it suddenly appeared probably just a bug.
Message 6 of 20
jeff.pek
Hi all -
We were having some problems in the back-end service that provides the machine library content. We believe these are resolved now. Please let us know if not.
Jeff
Message 7 of 20
jeff.pek
Note that it will require a Fusion restart to get it to go looking for the machines again.
  Jeff
Message 8 of 20
rfassberg
Looks good now after a restart today.   I can finally see the Fusion library.  Thanks for getting this fixed
Message 9 of 20
wpillinger
Indeed, it works now.
Thanks a lot for picking this up,
Regards
Message 10 of 20
phillip.r.prentice
I'm having the same issue.  Restarting Fusion 360 didn't help.
-Phil
Message 11 of 20
jeff.pek
Hmm. As far as I know, the system is operational. Can you show a screenshot of where you're not seeing machines?
BTW, can you try to manually access the following URL in a browser, and tell me what you see?
https://cam.autodesk.com/machines/machines/machines.json
  Jeff
Message 12 of 20
ananthsemail
Hi all,
Since last update, I'm facing the same issue with machine library. Usually there are several machines like EOS, ultimaker etc but now I can see only Autodesk generic FFF machine. Even other machines like turning, milling only few are listed but there used to be a lot more machines. Even restart fusion didn't worked and even re-installing also didn't worked. I think its my user related because on the same computer in my colleagues login, it shows all machines. So basically looks like a settings issue. BTW, Enable cloud libraries option under preferences is ticked on. Appreciate any help in this regard.
Message 13 of 20
jdw7122
Observer
Observer
Hi. Did you get this resolved? I'm having the exact same issue since latest update. Thanks!
Message 14 of 20
apwdesign
Community Visitor
Community Visitor
Also having the same issue. (Even after rebooting)
Message 15 of 20
bmorrow
Community Visitor
Community Visitor
any resolution?
Message 16 of 20
jeff.pek
Can you check the state of this item in Preview Features in Preferences?
Jeff
Message 17 of 20
mstickneyUNK39
Community Visitor
Community Visitor
Looks like this screw up was never fixed.  I can't fathom why someone would link to a DLL on the internet.  Did anyone have the sense to provide a method for a manual backup?  Or am I being too optimistic?
Message 18 of 20
echojjj
Fusion machine library is empty.  Restarting Fusion doesn't solve the problem.  The setting Automatically get latest Posts, Machines and Print Settings is marked.
Message 19 of 20
seth.madore
I'm sorry to hear that's happened to you. Have you worked thru the steps in this article?
If you navigate to your web storage (click on the "world" icon in the Data Panel), do you see your files there in the appropriate folder?
Seth Madore
Message 20 of 20
echojjj
Thanks for that.  I got it working with the Enable Cloud Libraries checkbox.  Not sure why it wouldn't be enabled by default.
