Freedom Machine Tool wood router with Fagor control queston
Tryingmybest
Message 1 of 29
Tryingmybest
I am currently using vcarve software to control my Fagor powered "Freedom" cnc router.  I am looking for something more robust.  Does anyone know if there is a post processor for fusion 360 that works with my router?
Replies (28)
Message 2 of 29
LibertyMachine
There is a Fagor generic post HERE
As always, posts can always be massaged to produce the code you need. Sample proven code and a list of accepted G and M codes would go a long way in guiding you in the proper direction
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 3 of 29
matthew.nichols
@Tryingmybest -
I am working on one for a freedom router currently with a customer. What fagor controller do you have on your machine? The one I am doing is an 8055
Matthew Nichols
Adoption Specialist - MFG
Message 4 of 29
Any luck with that fagor controller for the FMT?
I have a 4x8 Patriot router with a Fagor 8035 controller and ATC.  I'm able to mess around with the post for the 8055 a bit but i'm pretty green.  I got the machine to home ok, thanks to AtMan's youTube channel but I really need to figure out how to get the tool change working with tool offsets and all that G43 D(TOOL#) etc...  Also given that it's a router it would be great to be able to add an ORG statement which I currently use for Aspire.  Don't make me go back to Aspire!
Any help or update would be appreciated, Thanks.
scott
Message 5 of 29
matthew.nichols
I will post the one I currently have but if you have one that you have started modifying go ahead and attach it and I can review and update with tool change and ORG for you to test.
Matthew Nichols
Message 6 of 29
Hey Matt,
here's my latest that has an ORG statement going which seems to work.
Message 7 of 29
Tryingmybest
Hi all,
I am using a Fagor 8037M control on my Freedom Patriot 4x8 cnc router with a A.T.C and a 4th axis.  I spoke with Scott this weekend and my fingers are crossed that we can get a post for this machine.
Thanks for your time,
Dave
Message 8 of 29
matthew.nichols
@Tryingmybest @Anonymous
Here is a post for you guys to try.  Let me know if any errors come up or anything else that needs to be changed.
thank you,
Matthew Nichols
Message 9 of 29
Tryingmybest
Thanks Matt,
It might be awhile before I can get to it, but do you think it would work with the 4th axis?
Dave
Message 10 of 29
matthew.nichols
the previous one i attached won't because i missed adding the 4th axis stuff.  the one on this reply will post 4th axis moves.
Matthew Nichols
Message 11 of 29
Oh nice.
We might have some issues. For now maybe have a look at the post from Aspire to the FMT.  Noticed the
G51 E.01
G43 D2
these are key.
Also, the spindle speed has to come before the rotation direction like:
S12000 M3
Thanks, see attached.
s
Message 12 of 29
matthew.nichols
thank you for the example.  I will fix according to the example you sent and re-attach a revised version when completed.
Matthew Nichols
Message 13 of 29
Ok I have a new cps file if you don't have something newer.  I seem to be stuck at arcing and getting G3s when I should be getting G2s.  I can't believe it's taken this long to get something working i'm ready to throw in the towel. is there someone who just does this for a living that I can pay.  arg.
Message 14 of 29
matthew.nichols
I haven't quite gone dark on you; I just am able to do the posts when and if I have time.
You can get in touch with Tad Whitchurch at Hagerman and company or Derek at P9 CAM.
I apologize for all the time wasted and I wish it wouldn't have taken this long. Contact the 2 I told you about and let me know if you have any other questions.
Matthew Nichols
Message 15 of 29
matthew.nichols
@Anonymous
if you have a newer .cps file that you are looking at please post it on here with a file to test with as well.
I apologize again for this process taking so long.
Thank you,
Matthew Nichols
Message 16 of 29
Yeah i'm working with someone now on the post and will upload it when it's actually working.  No sense wasting anyone else's time on this.
Message 17 of 29
Tryingmybest
Will this be a 4th axis post by any chance?
Message 18 of 29
Since i'm now paying to have this done the short answer is no but i'm sure it'll give you a much better starting place then what is currently available.
Message 19 of 29
Tryingmybest
For sure,
How much will this cost you? If you don't want to share that info I understand.
Message 20 of 29
http://cam.autodesk.com/posts/post.php?name=freedom%20router%20fagor%208055
Try the above for any FMT that is newer than 2013 (Running the Fagor 8037 will work with the above)
For older than 2013 try using below
https://www.dropbox.com/s/7ty9hbh9k4da4dz/freedom%20router%20Pre%202013.cps?dl=0
If anyone runs into issues please feel free to get in touch with me directly at [email protected]. I am based in Colorado Springs, CO at the DMS/FMT factory.
Thanks everyone,
