Flip 2-side milling and trialing the Steep & Shallow
gj101
gj101
I am trying to mill this USMC emblem for my Dad and am running into some errors. Fully disclosure...this is my first time to use the steep and shallow function. I figured it best to resolve some of the complicated geometry.
It looks like it solves but when I go to simulate I get stock collision and and rapid movement into stock errors. I tried to order it to get it to cut by Z depth but am not sure what could be the issue.
Screenshot 2025-02-19 at 2.06.33 PM.pngScreenshot 2025-02-19 at 2.06.57 PM.pngScreenshot 2025-02-19 at 2.06.45 PM.png
a.laasW8M6T
Hi
Steep and shallow is a FINISHING toolpath, you will need to rough the part out with 3D adaptive or Pocket first before attempting finishing.
Try that first and then see how you get on
Andrew Laas
Senior Machinist, Scott Automation
gj101
I think the 3d adaptive pass helped! I added a long reach down cut to avoid some collision errors but there are some areas that still hit the stock. Also the fidelity is not great...
Screenshot 2025-02-19 at 4.35.10 PM.pngScreenshot 2025-02-19 at 4.35.15 PM.pngScreenshot 2025-02-19 at 4.35.32 PM.png
a.laasW8M6T
Try this
(view in My Videos)
Andrew Laas
gj101
Man that's awesome - thank you. Didn't think about the ball nose pass to smooth things out!
What's your preferred finishing method on this one...steep and shallow or the parallel? Obviously one requires more $ 🙂
a.laasW8M6T
I've always finished parts like this with Parallel with perpendicular passes, It does the job fine and is a bit quicker.
If you want a bit better surface finish steep and shallow will be better but that's probably only relevant on metals.
Andrew Laas
gj101
Gotcha. Thanks again for the help on this! ##- Please type your reply above
this line -##
*[email protected] || 512.993.7989
<512.993.7989> || Austin, Texas*
