First CNC project - Need help with excess stock and rapid collision errors
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This is my very first time working with CNC. I have a cheap 3-axis machine that I bought off of Amazon and I thought I'd start with something semi-complex because I learn best by diving into the deep end. So I thought I'd try to mill a 20 sided die (icosahedron). I imported a .stl from thingiverse and started playing around with generating toolpaths. I think I have the generated toolpaths that I like, but there's a couple problems. I'm attaching my .f3d file to help if anyone cares to look and I'm happy to answer questions, I'm just not sure what information I need to provide to be helpful.
First is in both my top and bottom operations I have a couple "Rapid collision with stock" errors during simulation that I just can't seem to fix.
Second is the remaining stock. Obviously I need to leave some so that it can remain connected to the stock so the piece remains stable, but right now with my generation there's at least 5 mm of uncut stock that I would have to try and sand off and hope I keep the correct angle. Is there any way I can reduce this amount? Another option would be to secure the piece with glue or double sided tape and let the machine cut the piece free of the stock such as enabling "Contact point boundary", but I can't find a toolpath generation strategy that doesn't try to cut all the way down to the bottom causing "Shaft collides with stock" errors.
Any help would be greatly appreciated.
