feed rate optimization - what am I missing
PeterBelfanti
Message 1 of 19
PeterBelfanti
Why am I not getting a feed rate reduction in the tightest corner of this pocket?  it reduces on larger radius but not the tightest ones?
Tool dia .125
Corner radius of part .081
Screen Shot 2017-09-09 at 10.10.45 AM.pngScreen Shot 2017-09-09 at 10.11.01 AM.png
Replies (18)
Message 2 of 19
Steinwerks
Deselect 'Only Inner Corners' as I believe this has been bugged for years now.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 3 of 19
PeterBelfanti
thank you for the tip..  I tried that just now and no difference in the path
Message 4 of 19
Steinwerks
Can you export as a .F3D and share the file here? That or make a quick dummy file with the same geometry that exhibits the same issue, it would be most helpful.
Neal Stein
Find me on:
Message 5 of 19
PeterBelfanti
part attached... one of the last paths in the current setup.
Message 6 of 19
Steinwerks
I had to drop the Maximal Directional Change all the way down to 5° which I believe is a function of the tool radius and the corner radius, but then it worked properly:
Edit: since there's quite a bit of material left after the previous roughing (you may want to consider reducing the minimum radius on that toolpath) if the Maximal Directional Change is reduced to 1° it will turn the full corner at the reduced feedrate.
Neal Stein
Find me on:
Message 7 of 19
PeterBelfanti
Thank you.. not greatly intuitive but if it works..
Message 8 of 19
Steinwerks
I can't be sure without some developer insight (want to chime in here, @fonsecr?) but I believe this has to do with the way that the directional change is calculated in conjunction with the tool radius.
I wouldn't be surprised in the slightest if the directional change distance calculated is a percentage of the tool radius interpolated as a straight line (think unwrapping the circumference), and so in your case where the corner geometry is significantly larger than the tool's radius, the calculated change in direction is quite small as the tool travels that radius.
I could be wrong, though, and now I'm curious and want answers Smiley Wink
Neal Stein
Find me on:
Message 9 of 19
fonsecr
Hmm, that doesn't look right.
I'll check it next week.
René Fonseca
Software Architect
Message 10 of 19
fonsecr
I see the problem now.
The inner corners is actually a lot of small line segments. Not an arc. The feed optimization currently support finding a global curvature across multiple segments.
You can turn on Points in the Simulate command to see this.
I dont have a solutions for this problem for now. I can bring it to the attention of the team - but I dont see this getting high priority at this time. But at least we now understand why it happened 🙂
René Fonseca
Software Architect
Message 11 of 19
fonsecr
Just one additional comment.
You can turn on smoothing which will fit arcs. And then these will get reduced feed due to the small radii. So an option when it is ok to use the Smoothing feature.
René Fonseca
Software Architect
Message 12 of 19
Steinwerks
Hah, I thought it was on. Oops. Setting it to .001" makes generation correct, as well as reducing the toolpath from 99.6kb to ~44kb.
Neal Stein
Find me on:
Message 13 of 19
PeterBelfanti
My fadal only has 128k. That matters! And it makes me sad.. back to dncx for me
Message 14 of 19
PeterBelfanti
Fonsecr
For your reference the model was 100% native to fusion 360. No import anomalies to create all those points.
Message 15 of 19
fonsecr
The toolpath strategies are using the triangulated surface to generate the toolpath which is why you get these points by default.
René Fonseca
Software Architect
Message 16 of 19
PeterBelfanti
The dirty underlying tessellated model.. needs a pretty dress.. kidding.. thanks for your help!!
Message 17 of 19
joshCPH3D
I have searched the forums for a couple of hours now. I've tried everything to get feed rate optimization to work. All I want is the tool to slow down in the inner corners of a square pocket. I've got my max directional change set to 1 deg, reduced feed radius at .001, distance at .5" and a large reduction in feed. My corners were drawn using the sketch fillet tool. I've tried everything. What am i missing here? I have attached a fusion file so anyone who wants can check out whats going on. Thanks in advance for any help!
Message 18 of 19
seth.madore
It's a deceptive field, that "Minimum Radius". One would think that it infers any radius larger than the entered field would be subject to a reduction in feedrate. That is not the case. Rather it's stating that anything SMALLER than the entered value would be subject to reduction
So, set it to a larger value. Simple math: radius of feature minus radius of tool. In this case, setting it to .064" gives me this:
Seth Madore
Message 19 of 19
joshCPH3D
Thanks so much! I've been using Fusion for years now and I've never taken the time to ask.
