Fanuc post modification
MarhallT
MarhallT
I purchased an older Hardinge lathe and I'm trying to make a few tweaks to the Fanuc post that is in the Fusion 360 post library. Attached are a sample file, the post processor and a posted file with the changes I am trying to make noted. Is there anyone who could make these modifications or answer some of the questions that I had in the notes? I have made some progress but I could use some help.
https://a360.co/40AR47U
Thanks!
yd_kwon
1. tool comment
Find the code below
writeToolBlock("T" + toolFormat.format(tool.number * 100 + compensationOffset));
    if (tool.comment) {
      writeComment(tool.comment);
Modify like below
    if (tool.comment) {
    if (getProperty("writeTools")){
      var zRange = currentSection.getGlobalZRange();
      var toolcomment = (tool.diameter != 0 ? "D=" + spatialFormat.format(tool.diameter) + " " : "") +
      (tool.isTurningTool() ? localize("NR") + "=" + spatialFormat.format(tool.noseRadius) : localize("CR") + "=" + spatialFormat.format(tool.cornerRadius)) +
      (tool.taperAngle > 0 && (tool.taperAngle < Math.PI) ? " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg") : "") +
      (zRange ? " - " + localize("ZMIN") + "=" + spatialFormat.format(zRange.getMinimum()) : "") +
       " - " + localize(getToolTypeName(tool.type));
      writeComment(toolcomment);
output
2. part catcher
Modify getcode()  below
function getCode(code) {
  switch (code) {
  case "PART_CATCHER_ON":
  return mFormat.format(26);
  case "PART_CATCHER_OFF":
  return mFormat.format(27);
output
CAM-Fusion 360/Inventor
CAD-Fusion 360/Inventor
Before PowerMILL
MarhallT
@yd_kwon Thank you for taking the time to look at this. Now I just need to figure what I need to modify on the threading, drilling, and tapping cycles.
