Hi
There is now one For Heidenhain, Siemens and Fanuc, You must add the Machine connector capability to the Machine definition:
Then you can pick it here
I'm not Familiar with Fanuc but the Heidenhain uses DCOM which is only available on the TNC640/620 as an option(18), and some newer iTNC530(and TNC7 but there's not many of those around yet)
@Richard.stubley may be able to give some more info these
Andrew Laas
Senior Machinist, Scott Automation
Super thank you !
I left the "Machine Connector Path" blank and when I tried running it, it gave the following error:
Where can I get the connector? I couldn't find one on the machine library. I'm running a Fanuc RoboDrill.
I'm not sure TBH
There only appears to be a Machine connector application for HAAS controls.
I don't have a Fanuc controller so cannot test this.
@seth.madore Do you know where the machine connector apps are for the other controls? Fanuc Heidenhain Seimens?
Or are they not actually need for those controls?
Andrew Laas
Oh, they're very much needed. It does appear that we haven't yet released them to the public. Let me check in with some folks who might know what the status is on them 🤔
So, it appears that we have:
Fanuc Machine Connector available here:
https://cam.autodesk.com/hsmposts?p=fanuc_inspection
Heidenhein is here:
https://cam.autodesk.com/hsmposts?p=heidenhain_inspection
I'm not sure where we're up to for the Siemens, let me check in with some folk and get back to you on that..
@AWFmatt @roland.bennerJLJT8 do either of you have a Siemens control with the RPC (Remote Procedure Call) option installed?
...no I don't have RPC option for Siemens.
