Failed to write output stream.
nicktoepfer
Message 1 of 10
nicktoepfer
I have been struggling over the last few days to get fusion to output g code.  I'm not sure what has changed but none of my parts will post even though I have posted them and cut them in the past.  The most current part that I am working on I receive the following message when I attempt tp post the code.  Strangely there is code when I open the TAP file that is saved by fusion but I don't want to run it with the message that I am given.
Information: Configuration: Mach3Mill
Information: Vendor: Artsoft
Information: Posting intermediate data to 'E:\cnc projects\raven 1.tap'
Error: Failed to post process. See below for details.
Code page changed to '1252  (ANSI - Latin I)'
Start time: Sunday, November 292020 12:24:05 AM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.5720.0
Configuration path: C:\Users\Nick\AppData\Local\Autodesk\webdeploy\production\ca426f89300c9832c554fb1598dc1364864ea03e\Applications\CAM360\Data\Posts\mach3mill.cps
Include paths: C:\Users\Nick\AppData\Local\Autodesk\webdeploy\production\ca426f89300c9832c554fb1598dc1364864ea03e\Applications\CAM360\Data\Posts
Configuration modification date: Wednesday, October 72020 2:07:07 PM
Output path: E:\cnc projects\raven 1.tap
Checksum of intermediate NC data: 96fc6170a6fc4c94d2a827c6ae869d6e
Checksum of configuration: d187e848dceac72ac216f7a2738be881
Legal: Copyright (C) 2012-2020 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.9313
Error: Failed to write output stream.
Error: Failed to execute configuration.
Stop time: Sunday, November 292020 12:24:07 AM
Error: Failed to close output stream.
Error in operation: 'Adaptive4'
Failed while processing onLinear() for record 20944.
Post processing failed.
Replies (9)
Message 2 of 10
daniel_lyall
Can you post a model that has this problem To attach a file Go to File -> Export and save as a .F3D Archive File and attach it to your next post, if you can not post the file you can PM it to me or say in your next post you can not post the file and one of the Guys that do NDA work will help.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 10
nicktoepfer
Thank you for the Quick reply.  Here is the file.
Message 4 of 10
daniel_lyall
It is fine for me.
What post are you using and is it a generic post?
Have you tried restarting the computer when this happens?
Daniel Lyall
The Big Boss
Mach3 User
Message 5 of 10
nicktoepfer
I have tried to re start the computer.  I have found that 90% of the time that corrects many issues...  it was not helpful in this one however.
I am using a machine produced by Bulkman3D so not exactly a high dollar machine, I use MACH 3, so I chose the Artsoft post process.  Am I making a mistake here?  Did something change in the last few weeks that I should have known about?
I have tried making new setups and ensuring that they are defined with a ucs.  the tool paths show correctly on the simulation and but fails when its time to post.  Like I say it will produce code if I open the TAP file after I close the warning window, but I don't trust it.
Message 6 of 10
daniel_lyall
That sound right, I don't know what the error means @GeorgeRoberts  do you know what the error means, please and thank you.
Daniel Lyall
The Big Boss
Mach3 User
Message 7 of 10
jeff.pek
This happens when there's some sort of error writing to the output. Did anything get written to the output file?
  Jeff
Message 8 of 10
nicktoepfer
It did write code for the part but I don't trust that it is correct and material is not easy to come by where I live so I did not run it.  I have attached it of you think that it may be helpful. (it wouldn't let me upload the TAP file so I copied the info into a txt file.)
Message 9 of 10
GeorgeRoberts
Thanks for tagging me @daniel_lyall . It looks to me like this could be a problem with the E drive you're posting to.  The 'failed to write output stream' usually occurs if the location you are posting to has some kind of permissions issue or if it gets changed in some way during writing.
Does this also happen if you post process to your local drive and then copy to E?
George Roberts
Manufacturing Product manager
If you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
Message 10 of 10
nicktoepfer
Interesting This was the issue.  It provided code and saved it to the E drive but didn't like it I appreciate all of the help that you guys have given.  Thank you and have a great holiday season.
