Failed to post process
Message 1 of 10
Post processing always fails after update today (5/21/2019). Same post process worked yesterday. Tried the most recent CNCRouterparts config from your site (.cps file), still fails. See Log below (edited out what I thought might be private with XXX's:
Information: Configuration: CNC Router Parts (Mach3Mill)
Information: Vendor: CNC Router Parts
Information: Posting intermediate data to 'J:\My Drive\CNC\CNC Offline\PD1 Test CNC Tripockets Only.tap'
Information: Total number of warnings: 3
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Tuesday, May 21, 2019 3:42:08 PM
Warning: function getProgramNameAsInt does not always return a value
Warning: function getProgramNameAsString does not always return a value
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.3.0 45221
Configuration path: c:/users/kmass/appdata/local/autodesk/autodesk fusion 360/XXX/w.login/m/XXX/camposts/cncrouterparts.cps
Include paths: c:/users/kmass/appdata/local/autodesk/autodesk fusion 360/XXX/w.login/m/XXX/camposts
Configuration modification date: Tuesday, May 21, 2019 3:39:39 PM
Output path: J:\My Drive\CNC\CNC Offline\PD1 Test CNC Tripockets Only.tap
Checksum of intermediate NC data: bc59cf7e65f158bdecacb2991615f42d
Checksum of configuration: c60e593bcc4faa0bf00ba8c1d0cd17c8
Vendor url: http://www.cncrouterparts.com
Legal: Copyright (C) 2012-2018 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.5790
Error: Invalid machine configuration in toolpath.
Error: Failed to execute configuration.
Stop time: Tuesday, May 21, 2019 3:42:08 PM
Post processing failed.
Replies (9)
Message 2 of 10
HughesTooling
This post might help.
https://forums.autodesk.com/t5/fusion-360-manufacture/machine-configurations-minor-issue-after-last-...
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 10
That seems to have fixed it, Thx Mark!!
Message 4 of 10
I am having this same issue after the latest update (November 2019)
I tried updating my HAAS Generic turning post processor but still having the same issue. I have not used the "machine configuration" options so not sure whats going on here or what the fix is.
Any ideas?
Thank you,
Message 5 of 10
I'm new here and can`t solve this problem with this warnings.
Thank you for help
Message 6 of 10
HughesTooling
@Anonymous   This looks like the problem are you using a 4 or 5 axis operation and your post doesn't support it.
Fehler: Error: Direction is not supported for machine configuration.
Error at line: 1
Are you trying to post to a machine with more than 3 axis or have you enabled tool orientation in an operation by mistake?
mark
Mark Hughes
Message 7 of 10
Try to check it. Give you response. Thanks.
Message 8 of 10
nc-code is generated, if the rotary axis is X or Y. Z is a problem. Have a post for 4 axis.
If I choose the multiaxis command rotary (millturn) in CAM, then always the rotary axis is changed to Z.
Don`t know why.
The next thing is the post. Wanted to modify from 4 to 5 axis.
Then a dream comes true.
cps attached. Can you help me?
Thanks  and many greetings from Austria
Message 9 of 10
HughesTooling
@seth.madore  Can you help with this?
Thanks Mark
Mark Hughes
Message 10 of 10
seth.madore
Just digging my way through the emails, sorry this took so long for a response. I've spent the last week moving my machine shop to the new building, and....it was a LOT of work.
Seth Madore
