Fadal post is not posting tapping cycle correctly
w.a.laliberte
w.a.laliberte
I love the newest post so far for fadal, but I have ran into a snag where it is posting the tap cycles in fadal format one and I no longer have a dialogue box to change that in the post processor settings. I have moved to an older post processor for the time being while tapping.
serge.quiblier
Hi @w.a.laliberte
can you explain with greater detail what is wrong in the output?
Can you share for example the old generated nc code, and the new one?
If changes needs to be implemented in the post, there is not enought information.
Regards.
Serge.Q
Technical Consultant
cam.autodesk.com
w.a.laliberte
I found that it was user error and i had the fadal format chose and not the fanuc which would be format two in the machine control.
serge.quiblier
I suppose it was that option causing the problem?
Serge.Q
cam.autodesk.com
w.a.laliberte
yes that is it!
markbECS9B
Observer
Observer
I am trying to tap and the fadal will not tap. the tool goes over the holes. Stops on each one but does not go down and tap. Have tried rh tap with ridged tried just RH without rigid. tapping with rigid and with out. Any ideas why ti will not work. Another programmer using feature cam has it working.
O1004 (PUNG GUIDE 1)
(T4 D=0.164 CR=0. - ZMIN=-0.547 - RIGHT HAND TAP)
N10 G90 G94 G17
N15 G20
N20 G28 G91 Z0.
N25 G90
(DRILL4)
N30 T4 M6
N35 S500 M3
N40 G4 P360
N45 G90 G94 G17
N50 M8
N55 G0 E1 X2.925 Y-0.375
N60 G43 Z0.6 H4
N65 Z0.2
N70 G98 G84 X2.925 Y-0.375 Z-0.547 R0+0.075 F15.625
N75 X1.675
N80 Y-1.625
N85 X2.925
N90 X7.675
N95 Y-0.375
N100 X8.925
N105 Y-1.625
N110 X13.675
N115 X14.925
N120 Y-0.375
N125 X13.675
N130 G80
N135 Z0.6
N140 M9
N145 G28 G91 Z0.
N150 G90
N155 G53 X0. Y0.
N160 M30
