Fadal Format 1 Post Processor
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I could never get *perfect* code out of the stock Fadal post processors. I went to work on the latest release, 43725. I now have ZERO manual edits, output goes straight to the machine and just runs. Use as you wish, no guarantees of fitness for you or your machine.
1. While the option is still there for Format 2, NOTHING was tested in that mode! My mods were only tested in Format 1.
2. G8 is basically automatic as required, if you enable it in post dialog as shown.
3. The default post would run the table all over and park at x0y0. You can now define a Load / Unload position in the post at line 1905. Once again there is an option for this in the post dialog as shown.
4. With the Load/Unload option, I discovered a 3 to 5 second delay to restart the program with two presses of the start button. The Loop Program option uses a GOTO and eliminates this. Again there is an option for this in the post dialog as shown.
5. Also fixed an issue with movement between fixtures being G1 and not G0.
Every line I edited has the comment "Myron" so you can see all my modifications.
Enjoy
