extra stock needed for corners
magpiemachining
Message 1 of 9
magpiemachining
Hi folks any one have any idea why i am having to leave more than .008 on the tool radius before these corners can clean up? the sides do but not the corners
Replies (8)
Message 2 of 9
daniel_lyall
What setup and toolpath
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 9
magpiemachining
mill op1
Message 4 of 9
daniel_lyall
I am not seeing anything really wrong at all.
Toolpath?
Screenshots or screencast?
Daniel Lyall
The Big Boss
Mach3 User
Message 5 of 9
magpiemachining
we either, the smoothing was at .004 before i changed it but no response from the path. i still had to leave more stock. the sides would clean up but not the corners.
Message 6 of 9
daniel_lyall
Are going by the sim in fusion or a backplot?
Daniel Lyall
The Big Boss
Mach3 User
Message 7 of 9
magpiemachining
can you explain what you mean? i am going by what happens in the machine
Message 8 of 9
daniel_lyall
Some people see a simulation of the tool paths in fusion and it looks wrong but is a graphics error and say something is wrong with the toolpath bla bla and it is not if you check the toolpath on the machine or in a backplot.
What machine are you using/controller
There have been problems with using smoothing in the past try with that turned off.
One thing that helps with finding problems is looking at the compear and edit and looking at view toolpath these are both in the right-click menu.
Daniel Lyall
The Big Boss
Mach3 User
Message 9 of 9
magpiemachining
there has been smoothing issues with the milltronics machine. several times we had a path violate a mold surface. the machine we are using for this part is a Mori mv50 with a msc500 fanuc control
