Export toolpath to CSV
dominik.reisach
dominik.reisach
Hello!
I need help exporting my toolpaths to a CSV file.
I tried using the Autodesk XYZ post-processor. It works fine when the Tool Orientation is the same as the WCS. However, as soon as I change the Tool Orientation (what I actually need to do!), the export fails.
The error message is "Tool orientation is not supported!" I don't get it... I just want the coordinates to be exported.
Can someone help me, please?
Best,
Dominik
seth.madore
You will need to add multi-axis support to your post processor. This guide can help you do just that.
Seth Madore
dominik.reisach
@seth.madoreThanks for your reply, but that didn't help. However, mingling with the .cps file made me find the issue:
function onSection() {
{ // pure 3D
var remaining = currentSection.workPlane;
if (!isSameDirection(remaining.forward, new Vector(0, 0, 1))) {
error(localize("Tool orientation is not supported."));
return;
setRotation(remaining);
It just commented out the if-statement and now it is working.
