Expanding bore
Expanding bore
gunnarid
Expanding bore
gunnarid
How do I bore expanding holes? The path is flipped the wrong way, not like the model. Is it possible?Bore.jpg
Steinwerks
Do you mean you need to make an undercut? You can do this with 3D Contour and Ramp IIRC but it will be "surfaced" which means stepdown will matter.
But yes, it is possible.
Edit: and you will need to use something like a radiused  woodruff or keyway cutter like this:
shankconvex22
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
gunnarid
Thank you, now everything is looking like it should 🙂
