Errors since Feb 2025 update
howardblackwell72
Observer Observer
Message 1 of 8
howardblackwell72
Observer
Observer
My machine is a 3 axis router with manual tool change only had problem since the above update .
Regards
Howard Blackwell
Replies (7)
Message 2 of 8
a.laasW8M6T
Hi
Connection moves in machine simulation are now turned on for all posts that support machine sim.
It seem however that your post is missing the part of the code that handles tool changes.
Is this a standard fusion post or a customised one?
If you could share a fusion file that demonstrates the problem and your post processor we can look into the issue
To share a fusion file goto File>export>save as .f3d/.f3z
You can export your post from the post library
Andrew Laas
Senior Machinist, Scott Automation
Message 3 of 8
CGBenner
@howardblackwell72
Hello, do you still need help with this question?
Chris Benner
Message 4 of 8
howardblackwell72
Observer
Observer
Apologies for not getting back sooner
Attached files you requested
grbl 2.cps BOX v6.f3z
Regards
Howard Blackwell
Message 5 of 8
a.laasW8M6T
Hi
There is no files attached.
You cannot attach files via email reply, you will need to use the web browser.
also for .f3z files make sure you Drag and drop them into the reply as using Browse doesn't work
Andrew Laas
Message 6 of 8
howardblackwell72
Observer
Observer
Hopefully you can see the files
Regards
Howard Blackwell
Message 7 of 8
a.laasW8M6T
Hi
I think this is a bug with the GRBL post in the Fusion library
@seth.madore can you get one of the post gurus to have a look?
@howardblackwell72  you can ignore the error for now i dont think its affecting anything
Andrew Laas
Message 8 of 8
seth.madore
I've opened up CAMP-3255 to investigate the matter, thank you for reporting!
Seth Madore
