Error with machinesimulation | weird axis movement
mbl_busse
mbl_busse
Hey there Community,
I've encountered a weird problem with the machinesimulation lately:
after starting the simulation the part and fixtures are not connected correct to the machine. The machine itself behaves also weirdly.
The part is oriented like this:
After I start the simulation this happens: (mind the seconds vice high up in the z-axis)
Even the orientation itself is wrong- I dont use any tilting in this operation.
The whole machinesimulation worked before with the exact same setting - same pp, same machine, same vice. Ive changed nothing in this regard. Just to be sure I did a new complete new machine just to make sure I have set all the axis right, but the problem is exisiting even with this new machine.
It's not the setup neither - if I insert the machine in a completely different setup its the same weird behaviour.
I hope someone has an Idea what I could have missed.
(I'm not allowed to share this file sadly...)
Thanks in advance
Janick
(in german: https://forums.autodesk.com/t5/fusion-360-deutsch/maschinensimulation-fehlerhaft-keine-bewegung-in-m... )
seth.madore
It seems that something has gone wrong with the Machine Definition. Can you program a dummy sample part that replicates the machine sim issue and share that?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply. To share the file privately, it's the same process, but email it to me: seth DOT madore AT autodesk DOT com
Seth Madore
mbl_busse
Hello there,
I just wanted to conclude this...
I was on vacation for the last three weeks. It seems like something got patched in the meantime because I dont get this behavior anymore, altough I didnt changed a thing..
So- I think we can close this. Thank you nevertheless!
Janick
