Error: Toolpath calculation failed. Error: Failed to process job.
eerier_bleach0f
eerier_bleach0f
I can't get either blend or flow to mill this:
I just get one of these errors/warnings:
Screenshot 2024-06-28 at 2.16.16 PM.pngScreenshot 2024-06-28 at 2.16.23 PM.png
Flow settings:
Screenshot 2024-06-28 at 2.17.19 PM.pngScreenshot 2024-06-28 at 2.17.23 PM.pngScreenshot 2024-06-28 at 2.17.27 PM.pngScreenshot 2024-06-28 at 2.17.32 PM.png
Blend settings:
Screenshot 2024-06-28 at 2.18.34 PM.pngScreenshot 2024-06-28 at 2.18.39 PM.pngScreenshot 2024-06-28 at 2.18.42 PM.pngScreenshot 2024-06-28 at 2.18.47 PM.png
Autodesk's most dedicated bug reporter: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/15188348
a.laasW8M6T
Hi
The tool you are trying to use is too big to fit in the area you are trying to mill, If you switch to a smaller tool it generates fine
With a 1.5mm ball nose
Andrew Laas
Senior Machinist, Scott Automation
