Error: Internal CAM kernel error. Please report through your support channel.
beykanaGHEQE
Message 1 of 9
beykanaGHEQE
Hello guys.
You're stuck with fusion today constantly "Error: Internal CAM kernel error. Please report it through your support channel." it crashes.
I rebuilt the program.
In a simple drawing, the gene did not give the same way. Is the problem general or verified from me?
Replies (8)
Message 2 of 9
seth.madore
Are you running Windows 7?
I'm probably telling you something you already know, but Win7 is no longer a supported OS, by Microsoft as well as Fusion 360. We have received reports of this issue, and are looking into it. I strongly encourage you to upgrade to Win10, it will likely be a lot quicker than us getting a fix out for this issue.
Seth Madore
Message 3 of 9
x371d4
Observer
Observer
Same issue here. Since the yesterday fusion 360 update I keep receiving the error "Internal CAM kernel error. Please report through your support channel". Every time I create a 2D pocket operation and generate the tool path I receive the error. Even for old parts where everything was OK if I generate the tool path again I will receive the error.
Any solution for the problem or need to wait until the next update?
Message 4 of 9
x371d4
Observer
Observer
Yes I am using windows 7. I know that fusion 360 is not anymore supported on windows 7 but changing to windows 10 is not an option. I have several applications that are only working in windows 7 and can't change only because of fusion 360.
Message 5 of 9
seth.madore
Then unfortunately, you're likely going to have to wait for a fix. I do not have an ETA on when that will be.
Seth Madore
Message 6 of 9
beykanaGHEQE
Yes, I am using Windows 7 too.
Message 7 of 9
jeff.pek
We believe we have a way to get folks using Windows 7 up and running again. We are looking for a volunteer to try out the fix before making it broadly available.
Please DM me if you are willing to try this out.
  Jeff
Message 8 of 9
spence.hatch
Community Visitor
Community Visitor
I would be happy to test this fix.
Message 9 of 9
seth.madore
@spence.hatch follow the instructions in THIS THREAD
Hope it helps!
Seth Madore
