Engraving path on diamond shaped objects - Round corners
I have an issue creating evenly shaped diamonds in fusion 360. When you look at the attached picture you see that the one side, where the Router starts to go in, is nice and sharp. The other side is just round. I have no clue why the results differ since it is just a symmetrical shape. I used the engrave module with an 2D shape.
The test project can be found under the following link.
The linked project uses 4 passes to slowly cut away the wood. But i gave it a shot with just one pass and very slow movement which resulted in the same issue.
I have tried several things and I am pretty sure it has something to do with Fusion and not my router nor my bit. I would be happy if someone can give a some advice how to convince Fusion360 to do the right thing. If you need anything else to help me please let me know.
Killimanjaro
