Engrave Improvements?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there any possibility that we are going to see much needed improvements in the area of Engrave?
"But, But.. We already have Engrave and look at all that v-carve we can do!"
Yeah, you know what I'm getting at and you KNOW that's not the answer. I need to simply machine engrave an incrementing serial number on a bunch of parts and it needs to look stellar under 20x magnification (customer request). Simply following a centerline at a constant Z depth is the way to go. None of this V-carve BS. That is what the machinists are looking for; quick and simple text engrave following a centerline and no varying Z heights.
I've watched the video in this reply, and I'm sorry, but I don't think the answer is to continue doing things the way that's shown. Can you imagine having to manually offset the centerline for dozens of texts with a S/N stretching out 16 digits?
And on top of that; the sizing and positioning of text could use some improvement. A .120" defined height does not necessarily yield that in actuality, depending on what font you are using.
Comments, thoughts, ideas?
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
