empty toolpath with 2d pocket rest-machining pass
I've read many of the solutions for this kind of problem but none seemed to address my setup, as simple as it is.
Where is a serious reference for selections that to ultimately generate toolpaths?
Briefly:  Cutting a u-shaped part, forks pointing up, so basically a 2-sided pocket.  2D adaptive works fine, leaving .02" stock.  Followup 2D pocket rest-maching gives me a no-passes-to-link error.
File is attached, much appreciation for any help.
thanks
MoshiurRashid
@seth.madore
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Empty reply?  There is nothing there except PM address but I don't know what to do there that would require 'privacy'.
seth.madore
He was tagging me to move this forum post to the correct forum. A lot of people go to the Support Forum with CAM questions, when they should be posting it in the Manufacture forum 😉
Seth Madore
seth.madore
The purpose (and the reason it's failing) of Rest Machining in the 2D Operations is to tell the toolpath to seek out radii and corners that are going to have material left over. Those don't exist on this part, so instead of just giving you a toolpath regardless, it fails. Turn off Rest Machining, as it's not doing anything for you 🙂
Seth Madore
Ah, good, thanks. Stock deliberately left in place is not the same as stock
that is un-reachable with the given tool size.
I ended up following 2D Adaptive Clearing with a 2D pocket that assumes
.02" left over stock from the previous operation. I guess I did a manual
rest-machining 🙂
I think I ended up this way because I was having problems doing multi-step
lateral finishing cuts in the 2D adaptive clearing.
Is there a more succinct solution?
thanks again!
