Drilling Toolpath errors
brad.long346
brad.long346
Community Visitor
Community Visitor
So, I don't know what happened this past update, but several of the toolpathing features are severely bugged out.  Mostly, it's the ones dealing with hole diameters of the same size, being selected drilling or milling.
Whenever I go to select all of the holes to be drilled, what used to be easily determined by the diameter range I set, Fusion says there are no holes to be drilled.
It also seems that this toolpath, severely lags my PC down (Acer Predator 300 gaming).  I'll keep trying till I get it to work, hopefully, but I have had no luck since I installed the new update yesterday.
seth.madore
Would you be able to share your Fusion file here or privately?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply. To share the file privately, it's the same process, but email it to me: seth DOT madore AT autodesk DOT com
Seth Madore
