03:15 PM
- Mute
- Permalink
- Report
Hey all,
I tried to do a drilling operation the other day but it did not work as expected on the machine. The toolpath looked correct and the simulation also appeared correct. But when the machine went to drill the holes, it only drill the first one. It proceeded to the location of the second hole and then to the third and fourth, but it did not go down to drill out the holes.
I use a post processor for the Shopsabre originally from @skidsolo which is attached.
I've recreated my problem with a simplified model:
G90 S16000 M3 G4 X4 G0 X101.600 Y25.400 Z40.400 G0 Z30.400 G81 X101.600 Y25.400 Z0.000 R30.400 F1355 #first hole drills G0 X25.400 #no indication of Z command for second hole G0 Y101.600 #third hole G0 X101.600 #fourth hole G80 G0 Z40.400 M5 G53 Z G53 Z X0Y0
