Doosan Post Processor
lucasD7TLR
lucasD7TLR
Hey everyone,
My current post processor is outputting code like below but I want to make an edit that will cause the post processor to place the M08 line right after the m03 spindle speed. Does anyone know how to accomplish this? I am using the
Doosan 3/5-axis VMC (FANUC) Post Processor Revision 40783.
(OP1 FACE)
N10
T28 M06
T4
S9831 M03
G54
G00 X6.65 Y-0.95
G43 Z0.365 H28
M08
G01 Z0.364 F100.
X-6.281
G00 Z0.365
Lucas
a.laasW8M6T
If you want to do it yourself, open up the .cps file and search "coolant"
search until you find
Cut that code out and paste it just before the command chip transport
I renamed the comment to reflect the change.
I'm not really sure why all the autodesk posts have the coolant on at the retract plane, on most machines the cutter will be well  into the workpeice before coolant starts flowing.
you should always carefully test any post changes to make sure you haven't broken anything
Hope that helps
Andrew Laas
Senior Machinist, Scott Automation
KrupalVala
Hi @lucasD7TLR,
Open you post processor in any editor. Go function onSection() { add below code as shown in screenshot
setCoolant(tool.coolant);
Now ignore the set coolant code (line number 1742) by adding //
save the post modification and test the code.
Krupal Vala
Senior Technology Consultant - Post Processor & Machine Simulation
lucasD7TLR
Thank you Krupal!
lucasD7TLR
Thank you!
