Do not repeat M# call
daniel_lyall
Mentor Mentor
daniel_lyall
How do you stop command from repeating when it is in the first part of the G code and at the end of the Gcode I know for the header you use && !isFirstSection() it is the M11 in red.
At the start
O1005
(POST PROG )
(TOOL MATERIAL )
(GENERATED ON WEDNESDAY, DECEMBER 11, 2019 103538)
(T3 D=6.35 CR=0. - FLAT END MILL)
N1 G90 G94 G17 G49 G00 G40 G80
N2 G21
N3 G53 G90 Z0.
(2D POCKET1)
N4 T3 M06
(BOSCH 14 SINGLE FLUTE)
N5 S20000 M03
N6 G54
N7 M11
at the end
N302 G93 B192.351 F1703.8
N303 G00 Z21.771
N304 G94
N305 G53 G90 Z0.
N306 G49
N307 G5.1 Q0
N308 M11
N309 G00 B0.
N310 M10
N311 G53 G90 X0. Y0.
N312 M30
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
engineguy
@daniel_lyall
Daniel
I would expect looking at the code around the M11 that to be found in the "onClose" area right at the end of the PP.
Regards
Rob
daniel_lyall
No, it is not in there it is in one places only in the Post Processor
 writeBlockmFormat.format (11) && something would go here to stop it repeating maybe());
 to stop it going in the first part of the G code you use what is below if it is in the header
if (properties.useSaftyLine && !isFirstSection()) {
Daniel Lyall
The Big Boss
Mach3 User
engineguy
@daniel_lyall
What PP is it? None of the PPs I use have an M11 in them at all, what is it being used for? Usually it is used along with M10 for clamping/unclamping.
Regards
Rob
daniel_lyall
It is a custom post it started life as a fanuc post, yes it is for clamping and unclamping using M10 and M11
Daniel Lyall
The Big Boss
Mach3 User
boopathi.sivakumar
@daniel_lyall
onclose() section comes into play at end of the total process,
move the code onsectionend() instead of onclose() and you can use
if (!isLastSection()){
then it will help you not post at the end of the code.
you can attach the post also i happy to have a look at it.
Boopathi Sivakumar
Principal Technology Consultant
daniel_lyall
@boopathi.sivakumar  Thanks I could not get what you suggested to work, I am more than likely doing it wrong I am not very good at coding, post attached it is not overly important.
Daniel Lyall
The Big Boss
Mach3 User
