Dmg Mori Cmx 800 Celos post processor
Janbickel91
Observer Observer
Message 1 of 11
Janbickel91
Observer
Observer
Hey Friends, really new to the cam world, I wonder if anyone has a post for a Dmg cmx 800 with celos? Started to get some quotes in and seems expensive, but again I'm completely new. Any recommendations or help welcome!
Replies (10)
Message 2 of 11
a.laasW8M6T
Celos is just DMG GUI front end, what controller is it actually running?
It could be Siemens or Heidenhain
is it just a basic 3 axis mill?
Andrew Laas
Senior Machinist, Scott Automation
Message 3 of 11
Janbickel91
Observer
Observer
Thanks for the answer!
It’s a Celos control, I think it runs mapps. Yes basic 3 axis.
Message 4 of 11
a.laasW8M6T
Hi
Like I mentioned CELOS isn't the controller its just DMG's user interface
see in this image from the DMG website the machine is offered with 3 options
Siemens, Heidenhain and Fanuc
If it is the Mapps Fanuc control then the Fanuc post processor from the library would be a good place to start
I would recommend paying someone to create a post for you as unless you are comfortable making modifications to the post yourself.
I would imagine for a basic machine such as this a post would only be a few hundred dollars for piece of mind in having the correct output
Andrew Laas
Message 5 of 11
ktorokU233T
@Janbickel91
If it is a CMX with a Fanuc control, just start with the AD post. And forget about the description of a DMG Mori CMX series horizontal machining center with optional rotary table and a FANUC control. This post is for the verticle.
Message 6 of 11
Janbickel91
Observer
Observer
So, I tried that post but it says on the machine "file can't be written''. Any ideas?
Message 7 of 11
AdamKunzo
It sounds like the machine might have trouble loading the NC code.
Do you have a programming manual for the machine or some sample codes from the machine?
I can help you to create a post processor for your machine, send me a message if'd like to get more information.
Message 8 of 11
AdamKunzo
Make sure you are not running Fanuc code on Heidenhain or Siemens 🙂
Take a photo of the machine control panel, at least we'll be able to identify the controller.
Message 9 of 11
Janbickel91
Observer
Observer
Sorry forgot: its a fanuc
Message 10 of 11
Janbickel91
Observer
Observer
Yea i got both, wanna sent me per email or on here?
Message 11 of 11
AdamKunzo
I sent you private message.
