Disable tool call fidia
nubrandao
nubrandao
Hi, does anyone knows how to disable tool call in fidia post processor? I opened fidia config, but not sure were i disable
a.laasW8M6T
Why do you want to disable the tool call?
How will the machine know which tool is in the spindle?
I assume you are talking about line N5 in this example?
Andrew Laas
Senior Machinist, Scott Automation
nubrandao
Because we have a lots of machines in the company, older machines that dont
have tool magazine, usually they use T0 or T1
They reference each tool manually and active
seth.madore
Do you want the active tool to be called and just remove the "next tool" call? Are all tools treated as T1, H1, D1?
Seth Madore
nubrandao
We work with single NC files, each toolpath has a NC file
I just want to add like "// tool call"
Just to the machine dont read tool call
seth.madore
Using the stock post, a couple of "//" at line 331:
Will get us this for code:
Seth Madore
nubrandao
Perfect thanks a lot
