- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there a method to the madness of selecting profiles and forcing them to be Inside or Outside and Conventional or Climb. If I take a open ended U shaped profile and select the lines with the Alt key pressed, it will give me random arrow directions and random sides of the cut within the three selections of the U shape. There must be a way to force it one way or another. I also have closed profiles on a part 54 of them, and I have to inspect each one to make sure the cutter is climb and inside the profile. Sometimes the arrows are underneath the highlighted profile and I spend a lot of time zooming in and out to cross check the selection. Anyway to force it or do I need to make sure I select the geometry a particular way before it gets highlighted?
