I'll try to be as descriptive as possible. I am almost at my wits end with this application because I get that the whole concept of CAD is complex, but I really think my issue is such a simple thing to do that Fusion360 just seems to struggle harder than anything I can imagine to accomplish.
In this case, I create a separate body to make the headstock round down and it seems to work well after what seems like 7000 attempts with adaptive clearing. Now, Im just trying to use Parallel like Austin Shaner does with a flat end mill to just smooth out the feature that will be raised on the headstock. For some unexplainable and maddening reason, Fusion usually seems to not want to cut anything but sometimes it wants to cut everything.
I just want it to stay in the clearly set boundaries I have, and follow the faces that are obvious, but it seems to want to cut in locations that don't make sense. I have posted the fusion file, an image of what it says it will cut, and images of what it actually does. As you can see, it seems to leave one side alone while the other side gets cut though there is no obvious reason why. You can see on the right side of the image it cuts along the right side. Incidentally, I have a tool path that clears that out on purpose and it works fine so even though I'd rather not see that cut in this path, it isn't gonna ruin the piece. On the left however, that is completely unacceptable and I can't see why it wants to do that to save my dog's life.
Side note, someone is going to demand i upload the f3z file and this site will not allow it. keeps removing from my post.
