Designing spur gears in Fusion 360 using Fusion 360 App Store Add in
I purchased and down loaded the Spur Gear Add in App from the Fusion 360 App Store.  However, I cant find it anywhere.  the only add in that shows up is the Fusion 360 Spur gear Add in that has the minimal options for creation.  can somoen tell me where it may be hiding?  The Video from its creator (Graham) shows you how to use it but it does not show you how to access it.
Thanks and standing by.
I love F-360
HughesTooling
If you click Add-Ins then click the Add-Ins tab does it show there. If it does and there no wheel to show it's running highlight it and click run.
Mark
Mark Hughes
Owner, Hughes Tooling
It is in the Add Ins list but no halo.  When I click run nothing at all happens.
HughesTooling
I guess you've tried selecting the app and click run a couple of times, the first time I tried with the gear script above nothing happened but the second time it started OK and added a new option at the bottom of the create menu in the model workspace. If it still doesn't work can you contact the app developer? Have you tried to start the gear script that comes with Fusion.
Mark
Mark Hughes
Yes the gear script that comes with Fusion works correctly.  I did send the developer an email but have not heard back yet.
It looked like from his video that his spur gear creator might be replacing the Fusion gear creator.  I say that because once he selected his spur gear creator from the add ins box he then went to the creator dtrop down and selected gear creat and his add in popped up and not the fusion gear creator.  I also tried uninstalling his Spur Gear Creator add in and then reinstalling and got the same result...it says it has installed susscessfully but doesnt come up.  Shoukld i try uninstalling the fusion gear add in and then install the new Spur Gear Creator program?
Thanks Greg
