customized machine kinematics
atdemo2019
atdemo2019
I wanted to customize the machine kinematics(to add rotary axis in left side of the machine),
I tried so many times but the machine simulation does not working.
somebody tell me how to do it.
Thankyou.
a.laasW8M6T
Hi
The file you uploaded didn't have a valid machine configuration so I couldn't do anything with it.
Try this one attached.
I have turned off TCP and also changed the orientation to Custom and set the Vector to -1 on the X.
This is possibly necessary for the Rotary being on the left, but you will need to confirm the rotary turns the correct direction on your actual machine
Andrew Laas
Senior Machinist, Scott Automation
atdemo2019
ok , I will try , Thanks for replying..
