Creating Toolpath for an Ellipse Profile
scott_nRBUC2
scott_nRBUC2
Hi everyone! I'm very new to fusion and CNC machining in general but have been drafting and modeling for a long while now. I have an elliptical profile that sweeps around a 12x12 piece I need to do for a mockup; the design part wasn't much of a hassle but I'm having trouble finding the right toolpath to use. Whatever I do seems to leave some stock that it shouldn't be. I've been exploring through the 3D paths in combination with the 2D contour, but haven't had any luck. I was planning on using a 1/4" ballend bit. Any help is greatly appreciated!
programming2C78B
I got flow to work in 3 clicks
Consider splitting it in 2 so it does both segments along their "long" axis
Please click "Accept Solution" if what I wrote solved your issue!
scott_nRBUC2
I realize I have a ways to go as far as learning is concerned 😅 What tool path type did you use for that?
programming2C78B
"FLOW"
scott_nRBUC2
Thank you, now if you'll excuse me I'm going to just walk straight into the ocean
programming2C78B
https://help.autodesk.com/view/fusion360/ENU/?guid=3D-FLOW-V2-STEPS
scott_nRBUC2
Thanks for the help, that last reply was meant to be comical as I go drown in my embarrassment at my ignorance. Unfortunately, text doesn't convey well. I got it goin
