creating folders for components
programming2C78B
Mentor Mentor
programming2C78B
this photo should speak 1000 words. would be great if I could throw this into a "fixturing" folder!
Please click "Accept Solution" if what I wrote solved your issue!
a.laasW8M6T
Components can act like folders(or containers) for other components
I have a Component called Fixture
Which contains all the Components that make up the Fixture
Andrew Laas
Senior Machinist, Scott Automation
programming2C78B
how does that work when all the fixture pieces are imported from other existing Fusion files?
a.laasW8M6T
You just activate the fixture component before inserting all the external files.
seeing as all the components have already been inserted in your picture you can also drag and drop all those components into the "Fixture" component.
(view in My Videos)
Andrew Laas
DarthBane55
🤯 did not know that, thanks!
programming2C78B
Thats a good enough work around for me, thanks.
