Creating Flat pattern for laser cutting
deanPEJDQ
deanPEJDQ
Community Visitor
Community Visitor
Hi all,
I'm currently creating fabrication files for a chair. There is one element that I am stuck on.
The seat pan is to be laser-cut, then rolled into the modelled form, but I can't seem to convert it to sheet metal to create a flat pattern/DXF.
I've tried offsetting the surface - created a tangent ruled surface from the edge - stitched both surfaces together - thickened to 3mm - then converted to sheet metal. Error comes up saying: Can't calculate body thickness. Select base face.
I've searched for videos online but can't fins a solution.
See pictures attached.
If someone could help, that would be great.
kacper.suchomski
Hi
It would be easier to respond if you attached your file.
Kacper Suchomski
lauri_barnhart
Hello @deanPEJDQ,
Thank you for posting your question in the community.
Kindly provide the file as @kacper.suchomski suggested so we as community can help solve your issue. You can also embed screenshots or attach a screencast recording to allow the community to assist further.
Looking forward to hearing back from you with more information so we, as a community, can help you!
All the best,
Lauri | Community Manager
